Irgendwie sieht das Log nicht so gut aus…wodran kann es liegen?
Die Kamera hat schon wieder das Admin-Passwort verändert…
 [Info] Translations loaded: 266 [Info] Initalize Mqtt [Info] Authenticate with Mqtt-Broker [Info] Connect to Mqtt-Broker 192.168.178.34 on port 1883... [Info] Initialize Fifo-Watcher [Warning] A file at the fifo filepath already exists, delete file and retry! [Info] Start Fifo-Watcher-Thread [Info] Start listening... [Info] Open fifo [Info] Synchronize Cgi-Server with Mqtt-Broker [Error] Translator failed to parse json format of the mqtt pipe:  [Warning] Failed to translate fifo_cgi wf_key ${val} [Error] Translator failed to parse json format of the mqtt pipe:  [Warning] Failed to translate fifo_cgi wf_key ${val} [Error] Translator failed to parse json format of the mqtt pipe:  [Warning] Failed to translate fifo_cgi wf_key ${val} [Error] Translator failed to parse json format of the mqtt pipe:  [Warning] Failed to translate fifo_cgi wf_key ${val} [Error] Translator failed to parse json format of the mqtt pipe:  [Warning] Failed to translate fifo_cgi wf_key  [Error] Translator failed to parse json format of the mqtt pipe:  [Warning] Failed to translate fifo_cgi wf_key  [Error] Translator failed to parse json format of the mqtt pipe:  [Warning] Failed to translate fifo_cgi wf_key  [Error] Translator failed to parse json format of the mqtt pipe:  [Warning] Failed to translate fifo_cgi wf_key  [Error] Translator doesn't fit to passed values, index != value [Warning] Failed to translate fifo_cgi index 32 [Error] Translator doesn't fit to passed values, index != value [Warning] Failed to translate fifo_cgi index 32 [Error] Translator doesn't fit to passed values, index != value [Warning] Failed to translate fifo_cgi index 32 [Error] Translator doesn't fit to passed values, index != value [Warning] Failed to translate fifo_cgi index 32 [Error] Translator doesn't fit to passed values, index != value [Warning] Failed to translate fifo_cgi index 32 [Error] Translator doesn't fit to passed values, index != value [Warning] Failed to translate fifo_cgi index 32 [Error] Translator doesn't fit to passed values, index != value [Warning] Failed to translate fifo_cgi index 32 [Error] Translator doesn't fit to passed values, index != value [Warning] Failed to translate fifo_cgi index 32 [Error] Translator doesn't fit to passed values, chn != aeswitch [Warning] Failed to translate fifo_cgi chn 11 [Error] Translator doesn't fit to passed values, chn != aeswitch [Warning] Failed to translate fifo_cgi chn 11 [Error] Translator doesn't fit to passed values, chn != aeswitch [Warning] Failed to translate fifo_cgi chn 11 [Error] Translator doesn't fit to passed values, chn != aeswitch [Warning] Failed to translate fifo_cgi chn 11 [Error] Translator doesn't fit to passed values, chn != aeswitch [Warning] Failed to translate fifo_cgi chn 11 [Error] Translator doesn't fit to passed values, chn != aeswitch [Warning] Failed to translate fifo_cgi chn 11 [Error] Translator doesn't fit to passed values, chn != aeswitch [Warning] Failed to translate fifo_cgi chn 11 [Error] Translator doesn't fit to passed values, chn != aeswitch [Warning] Failed to translate fifo_cgi chn 11 [Error] Translator doesn't fit to passed values, chn != aeswitch [Warning] Failed to translate fifo_cgi chn 12 [Error] Translator doesn't fit to passed values, chn != aeswitch [Warning] Failed to translate fifo_cgi chn 12 [Error] Translator doesn't fit to passed values, chn != aeswitch [Warning] Failed to translate fifo_cgi chn 12 [Error] Translator doesn't fit to passed values, chn != aeswitch [Warning] Failed to translate fifo_cgi chn 12 [Error] Translator doesn't fit to passed values, chn != aeswitch [Warning] Failed to translate fifo_cgi chn 12 [Error] Translator doesn't fit to passed values, chn != aeswitch [Warning] Failed to translate fifo_cgi chn 12 [Error] Translator doesn't fit to passed values, chn != aeswitch [Warning] Failed to translate fifo_cgi chn 12 [Error] Translator doesn't fit to passed values, chn != aeswitch [Warning] Failed to translate fifo_cgi chn 12 [Error] Translator doesn't fit to passed values, chn != aeswitch [Warning] Failed to translate fifo_cgi chn 13 [Error] Translator doesn't fit to passed values, chn != aeswitch [Warning] Failed to translate fifo_cgi chn 13 [Error] Translator doesn't fit to passed values, chn != aeswitch [Warning] Failed to translate fifo_cgi chn 13 [Error] Translator doesn't fit to passed values, chn != aeswitch [Warning] Failed to translate fifo_cgi chn 13 [Error] Translator doesn't fit to passed values, chn != aeswitch [Warning] Failed to translate fifo_cgi chn 13 [Error] Translator doesn't fit to passed values, chn != aeswitch [Warning] Failed to translate fifo_cgi chn 13 [Error] Translator doesn't fit to passed values, chn != aeswitch [Warning] Failed to translate fifo_cgi chn 13 [Error] Translator doesn't fit to passed values, chn != aeswitch [Warning] Failed to translate fifo_cgi chn 13 [Error] Translator doesn't fit to passed values, chn != bps [Warning] Failed to translate fifo_cgi chn 11 [Error] Translator doesn't fit to passed values, chn != bps [Warning] Failed to translate fifo_cgi chn 11 [Error] Translator doesn't fit to passed values, chn != bps [Warning] Failed to translate fifo_cgi chn 11 [Error] Translator doesn't fit to passed values, chn != bps [Warning] Failed to translate fifo_cgi chn 11 [Error] Translator doesn't fit to passed values, chn != bps [Warning] Failed to translate fifo_cgi chn 11 [Error] Translator doesn't fit to passed values, chn != bps [Warning] Failed to translate fifo_cgi chn 11 [Error] Translator doesn't fit to passed values, chn != bps [Warning] Failed to translate fifo_cgi chn 11 [Error] Translator doesn't fit to passed values, chn != bps [Warning] Failed to translate fifo_cgi chn 11 [Error] Translator doesn't fit to passed values, chn != bps [Warning] Failed to translate fifo_cgi chn 12 [Error] Translator doesn't fit to passed values, chn != bps [Warning] Failed to translate fifo_cgi chn 12 [Error] Translator doesn't fit to passed values, chn != bps [Warning] Failed to translate fifo_cgi chn 12 [Error] Translator doesn't fit to passed values, chn != bps [Warning] Failed to translate fifo_cgi chn 12 [Error] Translator doesn't fit to passed values, chn != bps [Warning] Failed to translate fifo_cgi chn 12 [Error] Translator doesn't fit to passed values, chn != bps [Warning] Failed to translate fifo_cgi chn 12 [Error] Translator doesn't fit to passed values, chn != bps [Warning] Failed to translate fifo_cgi chn 12 [Error] Translator doesn't fit to passed values, chn != bps [Warning] Failed to translate fifo_cgi chn 12 [Error] Translator doesn't fit to passed values, chn != bps [Warning] Failed to translate fifo_cgi chn 13 [Error] Translator doesn't fit to passed values, chn != bps [Warning] Failed to translate fifo_cgi chn 13 [Error] Translator doesn't fit to passed values, chn != bps [Warning] Failed to translate fifo_cgi chn 13 [Error] Translator doesn't fit to passed values, chn != bps [Warning] Failed to translate fifo_cgi chn 13 [Error] Translator doesn't fit to passed values, chn != bps [Warning] Failed to translate fifo_cgi chn 13 [Error] Translator doesn't fit to passed values, chn != bps [Warning] Failed to translate fifo_cgi chn 13 [Error] Translator doesn't fit to passed values, chn != bps [Warning] Failed to translate fifo_cgi chn 13 [Error] Translator doesn't fit to passed values, chn != bps [Warning] Failed to translate fifo_cgi chn 13 [Error] Translator doesn't fit to passed values, chn != imagegrade [Warning] Failed to translate fifo_cgi chn 11 [Error] Translator doesn't fit to passed values, chn != imagegrade [Warning] Failed to translate fifo_cgi chn 11 [Error] Translator doesn't fit to passed values, chn != imagegrade [Warning] Failed to translate fifo_cgi chn 11 [Error] Translator doesn't fit to passed values, chn != imagegrade [Warning] Failed to translate fifo_cgi chn 11 [Error] Translator doesn't fit to passed values, chn != imagegrade [Warning] Failed to translate fifo_cgi chn 11 [Error] Translator doesn't fit to passed values, chn != imagegrade [Warning] Failed to translate fifo_cgi chn 11 [Error] Translator doesn't fit to passed values, chn != imagegrade [Warning] Failed to translate fifo_cgi chn 11 [Error] Translator doesn't fit to passed values, chn != imagegrade [Warning] Failed to translate fifo_cgi chn 11 [Error] Translator doesn't fit to passed values, chn != imagegrade [Warning] Failed to translate fifo_cgi chn 12 [Error] Translator doesn't fit to passed values, chn != imagegrade [Warning] Failed to translate fifo_cgi chn 12 [Error] Translator doesn't fit to passed values, chn != imagegrade [Warning] Failed to translate fifo_cgi chn 12 [Error] Translator doesn't fit to passed values, chn != imagegrade [Warning] Failed to translate fifo_cgi chn 12 [Error] Translator doesn't fit to passed values, chn != imagegrade [Warning] Failed to translate fifo_cgi chn 12 [Error] Translator doesn't fit to passed values, chn != imagegrade [Warning] Failed to translate fifo_cgi chn 12 [Error] Translator doesn't fit to passed values, chn != imagegrade [Warning] Failed to translate fifo_cgi chn 12 [Error] Translator doesn't fit to passed values, chn != imagegrade [Warning] Failed to translate fifo_cgi chn 12 [Error] Translator doesn't fit to passed values, chn != imagegrade [Warning] Failed to translate fifo_cgi chn 13 [Error] Translator doesn't fit to passed values, chn != imagegrade [Warning] Failed to translate fifo_cgi chn 13 [Error] Translator doesn't fit to passed values, chn != imagegrade [Warning] Failed to translate fifo_cgi chn 13 [Error] Translator doesn't fit to passed values, chn != imagegrade [Warning] Failed to translate fifo_cgi chn 13 [Error] Translator doesn't fit to passed values, chn != imagegrade [Warning] Failed to translate fifo_cgi chn 13 [Error] Translator doesn't fit to passed values, chn != imagegrade [Warning] Failed to translate fifo_cgi chn 13 [Error] Translator doesn't fit to passed values, chn != imagegrade [Warning] Failed to translate fifo_cgi chn 13 [Error] Translator doesn't fit to passed values, chn != imagegrade [Warning] Failed to translate fifo_cgi chn 13 [Error] Translator doesn't fit to passed values, chn != brmode [Warning] Failed to translate fifo_cgi chn 11 [Error] Translator doesn't fit to passed values, chn != brmode [Warning] Failed to translate fifo_cgi chn 11 [Error] Translator doesn't fit to passed values, chn != brmode [Warning] Failed to translate fifo_cgi chn 11 [Error] Translator doesn't fit to passed values, chn != brmode [Warning] Failed to translate fifo_cgi chn 11 [Error] Translator doesn't fit to passed values, chn != brmode [Warning] Failed to translate fifo_cgi chn 11 [Error] Translator doesn't fit to passed values, chn != brmode [Warning] Failed to translate fifo_cgi chn 11 [Error] Translator doesn't fit to passed values, chn != brmode [Warning] Failed to translate fifo_cgi chn 11 [Error] Translator doesn't fit to passed values, chn != brmode [Warning] Failed to translate fifo_cgi chn 11 [Error] Translator doesn't fit to passed values, chn != brmode [Warning] Failed to translate fifo_cgi chn 12 [Error] Translator doesn't fit to passed values, chn != brmode [Warning] Failed to translate fifo_cgi chn 12 [Error] Translator doesn't fit to passed values, chn != brmode [Warning] Failed to translate fifo_cgi chn 12 [Error] Translator doesn't fit to passed values, chn != brmode [Warning] Failed to translate fifo_cgi chn 12 [Error] Translator doesn't fit to passed values, chn != brmode [Warning] Failed to translate fifo_cgi chn 12 [Error] Translator doesn't fit to passed values, chn != brmode [Warning] Failed to translate fifo_cgi chn 12 [Error] Translator doesn't fit to passed values, chn != brmode [Warning] Failed to translate fifo_cgi chn 12 [Error] Translator doesn't fit to passed values, chn != brmode [Warning] Failed to translate fifo_cgi chn 12 [Error] Translator doesn't fit to passed values, chn != brmode [Warning] Failed to translate fifo_cgi chn 13 [Error] Translator doesn't fit to passed values, chn != brmode [Warning] Failed to translate fifo_cgi chn 13 [Error] Translator doesn't fit to passed values, chn != brmode [Warning] Failed to translate fifo_cgi chn 13 [Error] Translator doesn't fit to passed values, chn != brmode [Warning] Failed to translate fifo_cgi chn 13 [Error] Translator doesn't fit to passed values, chn != brmode [Warning] Failed to translate fifo_cgi chn 13 [Error] Translator doesn't fit to passed values, chn != brmode [Warning] Failed to translate fifo_cgi chn 13 [Error] Translator doesn't fit to passed values, chn != brmode [Warning] Failed to translate fifo_cgi chn 13 [Error] Translator doesn't fit to passed values, chn != brmode [Warning] Failed to translate fifo_cgi chn 13 [Error] Translator doesn't fit to passed values, chn != fps [Warning] Failed to translate fifo_cgi chn 11 [Error] Translator doesn't fit to passed values, chn != fps [Warning] Failed to translate fifo_cgi chn 11 [Error] Translator doesn't fit to passed values, chn != fps [Warning] Failed to translate fifo_cgi chn 11 [Error] Translator doesn't fit to passed values, chn != fps [Warning] Failed to translate fifo_cgi chn 11 [Error] Translator doesn't fit to passed values, chn != fps [Warning] Failed to translate fifo_cgi chn 11 [Error] Translator doesn't fit to passed values, chn != fps [Warning] Failed to translate fifo_cgi chn 11 [Error] Translator doesn't fit to passed values, chn != fps [Warning] Failed to translate fifo_cgi chn 11 [Error] Translator doesn't fit to passed values, chn != fps [Warning] Failed to translate fifo_cgi chn 11 [Error] Translator doesn't fit to passed values, chn != fps [Warning] Failed to translate fifo_cgi chn 12 [Error] Translator doesn't fit to passed values, chn != fps [Warning] Failed to translate fifo_cgi chn 12 [Error] Translator doesn't fit to passed values, chn != fps [Warning] Failed to translate fifo_cgi chn 12 [Error] Translator doesn't fit to passed values, chn != fps [Warning] Failed to translate fifo_cgi chn 12 [Error] Translator doesn't fit to passed values, chn != fps [Warning] Failed to translate fifo_cgi chn 12 [Error] Translator doesn't fit to passed values, chn != fps [Warning] Failed to translate fifo_cgi chn 12 [Error] Translator doesn't fit to passed values, chn != fps [Warning] Failed to translate fifo_cgi chn 12 [Error] Translator doesn't fit to passed values, chn != fps [Warning] Failed to translate fifo_cgi chn 12 [Error] Translator doesn't fit to passed values, chn != fps [Warning] Failed to translate fifo_cgi chn 13 [Error] Translator doesn't fit to passed values, chn != fps [Warning] Failed to translate fifo_cgi chn 13 [Error] Translator doesn't fit to passed values, chn != fps [Warning] Failed to translate fifo_cgi chn 13 [Error] Translator doesn't fit to passed values, chn != fps [Warning] Failed to translate fifo_cgi chn 13 [Error] Translator doesn't fit to passed values, chn != fps [Warning] Failed to translate fifo_cgi chn 13 [Error] Translator doesn't fit to passed values, chn != fps [Warning] Failed to translate fifo_cgi chn 13 [Error] Translator doesn't fit to passed values, chn != fps [Warning] Failed to translate fifo_cgi chn 13 [Error] Translator doesn't fit to passed values, chn != fps [Warning] Failed to translate fifo_cgi chn 13 [Error] Translator doesn't fit to passed values, chn != gop [Warning] Failed to translate fifo_cgi chn 11 [Error] Translator doesn't fit to passed values, chn != gop [Warning] Failed to translate fifo_cgi chn 11 [Error] Translator doesn't fit to passed values, chn != gop [Warning] Failed to translate fifo_cgi chn 11 [Error] Translator doesn't fit to passed values, chn != gop [Warning] Failed to translate fifo_cgi chn 11 [Error] Translator doesn't fit to passed values, chn != gop [Warning] Failed to translate fifo_cgi chn 11 [Error] Translator doesn't fit to passed values, chn != gop [Warning] Failed to translate fifo_cgi chn 11 [Error] Translator doesn't fit to passed values, chn != gop [Warning] Failed to translate fifo_cgi chn 11 [Error] Translator doesn't fit to passed values, chn != gop [Warning] Failed to translate fifo_cgi chn 11 [Error] Translator doesn't fit to passed values, chn != gop [Warning] Failed to translate fifo_cgi chn 12 [Error] Translator doesn't fit to passed values, chn != gop [Warning] Failed to translate fifo_cgi chn 12 [Error] Translator doesn't fit to passed values, chn != gop [Warning] Failed to translate fifo_cgi chn 12 [Error] Translator doesn't fit to passed values, chn != gop [Warning] Failed to translate fifo_cgi chn 12 [Error] Translator doesn't fit to passed values, chn != gop [Warning] Failed to translate fifo_cgi chn 12 [Error] Translator doesn't fit to passed values, chn != gop [Warning] Failed to translate fifo_cgi chn 12
