die Kamera funktioniert soweit, aber ich kann nicht mehr über den Browser auf das Menü zu greifen. Nach dem Login kommt folgende Meldung:
Index of
[TABLE=„cellpadding: 0“]
[TR]
Name Modified Size [/TR]
[TR]
[TD=„colspan: 3“] [HR][/HR][/TD]
[/TR]
[TR]
[TD]Parent directory[/TD]
[TD] -[/TD]
[TD] -[/TD]
[/TR]
[TR]
[TD]css/[/TD]
[TD] 19-Apr-2019 12:33[/TD]
[TD] [DIRECTORY][/TD]
[/TR]
[TR]
[TD]flash/[/TD]
[/TR]
[TR]
[TD]images/[/TD]
[TD] 19-Apr-2019 12:34[/TD]
[/TR]
[TR]
[TD]java/[/TD]
[/TR]
[TR]
[TD]log/[/TD]
[TD] 30-Oct-2019 08:06[/TD]
[/TR]
[TR]
[TD]sd/[/TD]
[TD] 01-Jan-1970 02:00[/TD]
[/TR]
[TR]
[TD]tmpfs/[/TD]
[/TR]
[TR]
[TD]wizard/[/TD]
[/TR]
[TR]
[TD]admin.html[/TD]
[TD] 21.1k[/TD]
[/TR]
[TR]
[TD]afterBackup.html[/TD]
[TD] 2.7k[/TD]
[/TR]
[TR]
[TD]afterReset.html[/TD]
[TD] 2.3k[/TD]
[/TR]
[TR]
[TD]afterUpdate.html[/TD]
[TD] 5.4k[/TD]
[/TR]
[TR]
[TD]alarm.html[/TD]
[TD] 9.6k[/TD]
[/TR]
[TR]
[TD]alarm_6014.html[/TD]
[TD] 8.4k[/TD]
[/TR]
[TR]
[TD]area.html[/TD]
[TD] 41.0k[/TD]
[/TR]
[TR]
[TD]md.html[/TD]
[TD] 25.2k[/TD]
[/TR]
[TR]
[TD]onvif.html[/TD]
[TD] 4.0k[/TD]
[/TR]
[TR]
[TD]photoseries.html[/TD]
[TD] 5.9k[/TD]
[/TR]
[TR]
[TD]ptz.html[/TD]
[TD] 8.8k[/TD]
[/TR]
[TR]
[TD]ptzparty.html[/TD]
[TD] 8.7k[/TD]
[/TR]
[TR]
[TD]ptztour.html[/TD]
[TD] 6.7k[/TD]
[/TR]
[TR]
[TD]push.html[/TD]
[TD] 1.1k[/TD]
[/TR]
[TR]
[TD]recorder-plans.html[/TD]
[TD] 2.9k[/TD]
[/TR]
[TR]
[TD]recorder-vid.html[/TD]
[TD] 3.9k[/TD]
[/TR]
[TR]
[TD]recorder_info.htm[/TD]
[TD] 20.6k[/TD]
[/TR]
[TR]
[TD]schedule.html[/TD]
[TD] 6.9k[/TD]
[/TR]
[TR]
[TD]sd-card.html[/TD]
[TD] 2.5k[/TD]
[/TR]
[TR]
[TD]smtp.html[/TD]
[TD] 5.9k[/TD]
[/TR]
[TR]
[TD]snapshot.html[/TD]
[TD] 1.0k[/TD]
[/TR]
[TR]
[TD]status-led.html[/TD]
[TD] 1.8k[/TD]
[/TR]
[TR]
[TD]syslog.html[/TD]
[TD] 2.3k[/TD]
[/TR]
[TR]
[TD]time.html[/TD]
[TD] 14.6k[/TD]
[/TR]
[TR]
[TD]tunnel.html[/TD]
[TD] 1.2k[/TD]
[/TR]
[TR]
[TD]update.html[/TD]
[TD] 2.7k[/TD]
[/TR]
[TR]
[TD]update_log[/TD]
[TD] 02-May-2019 11:48[/TD]
[TD] 719[/TD]
[/TR]
[TR]
[TD]updatestate.html[/TD]
[TD] 6.7k[/TD]
[/TR]
[TR]
[TD]upnp.html[/TD]
[TD] 1.8k[/TD]
[/TR]
[TR]
[TD]user.html[/TD]
[TD] 10.1k[/TD]
[/TR]
[TR]
[TD]video.html[/TD]
[TD] 9.7k[/TD]
[/TR]
[TR]
[TD]view.html[/TD]
[TD] 6.4k[/TD]
[/TR]
[TR]
[TD]web.ini[/TD]
[TD] 40[/TD]
[/TR]
[TR]
[TD]wifi.html[/TD]
[TD] 3.3k[/TD]
[/TR]
[TR]
[TD]wizard_1.htm[/TD]
[TD] 10.2k[/TD]
[/TR]
[TR]
[TD]wizard_2.htm[/TD]
[TD] 14.1k[/TD]
[/TR]
[TR]
[TD]wizard_3.htm[/TD]
[TD] 6.9k[/TD]
[/TR]
[TR]
[TD]wizard_4.htm[/TD]
[TD] 4.4k[/TD]
[/TR]
[TR]
[TD]wizard_end.htm[/TD]
[TD] 3.3k[/TD]
[/TR]
[TR]
[TD]wizard_reboot.htm[/TD]
[TD] 4.2k[/TD]
[/TR]
[TR]
[TD]wizard_start.html[/TD]
[TD] 2.1k[/TD]
[/TR]
[/TABLE]
Woran kann das liegen?
Vielen Dank,
Mac
